After class tonight I stayed late running 3F vertical fillets with 7018, and a journeyman let me try his hood while he pointed me to the Miller weld settings app and our local AWS section meetup. I’m trying to build skills and a real network fast — what apps, pocket guides, or groups have moved the needle for you?
Second the Miller app, but the Lincoln Welding Calculator has saved me when I’m brain‑fried after running 3F 7018 — quick amps/volts/rod size and a decent preheat reminder. Also, toss a cheap fillet gauge in your pocket so you can check leg size between passes; ugh, guessing by eye wastes coupons. Drop your city and I can point you to an AWS section or shop night that’s active.
Since you’re grinding through 3F 7018 after class, make a mini WPS card (amps window, arc length, weave limit) and tape it inside your hood — saves me when my brain’s cooked. Show up 15 minutes early to your AWS section and volunteer for bend-test/coupon prep; you’ll meet the CWI and the folks who hire. For a pocket reference, Pipefitter’s Blue Book is clutch for quick takeoffs and fit-up math — want the page numbers I marked?
I keep the ESAB Weld Parameter Guide app for quick ranges and the HIWT Pocket Welding Guide in my bag — a glovebox “mini WPS” you can’t lose. For networking, hit maker‑space open shop nights via https://www.meetup.com/find/?keywords=welding and show up with a couple of clean coupons and a fillet gauge; you’ll meet people fast.
After those late sessions, a cheap IR thermometer saved me — I keep the plate around 150–200°F between beads so I’m not chasing a mushy puddle, . For quick numbers beyond the Miller app, the Lincoln Arc Welding Calculator is solid: https://www.lincolnelectric.com/en/Support/welding-calculators. If you’re hitting the AWS meetup, bring a couple small practice plates and ask for a 10‑minute “watch my hands” review — want the tiny checklist I use?
Since you “stayed late running 3F with 7018,” try a metronome app around 65–70 bpm to pace a tiny U-weave — sounds goofy, but it tightened my toes and kept arc time consistent… For quick checks, Lincoln’s WeldCalc is fine, but a 250–300°F Tempilstik beats an IR gun on scale-y plate — , reflections skew readings. Networking: hit your local welding supplier’s demo nights (Airgas/Linde) and ask the rep who’s placing hands this month; I landed two shop tryouts that way.
Quick win: the Lincoln Weld Calculator app (https://www.lincolnelectric.com/en/weld-calculator) for ranges, then treat practice like a food diary — snap a pic of each plate and caption amps/volts/travel so you can see what improved things a week later. If you’re already hitting the AWS meetup, @jfoster’s pacing tip plus a logbook makes feedback sharper; want a dead‑simple note template?
