Maximizing Efficiency in Robotic Welding
I’ve been experimenting with different programming strategies to enhance our robotic welding line’s efficiency and I’ve noticed a significant impact on cycle times. Has anyone else tried tweaking their G-code to optimize parameters for specific materials? I’m focusing on steel and seems like minor adjustments lead to less waste and better fusion.
I’ve found that adjusting the travel speed can really make a difference, especially with > steel and seems like minor adjustments lead to less waste and better fusion. Sometimes it’s just about finding that sweet spot for the specific batch. Have you tried varying the amperage too?
Tweaking the arc voltage can really help with steel too. Have you tested that? It can affect penetration quality significantly.
I’ve had luck adjusting the wire feed speed, especially for steel. It can really help with fusion. What specific adjustments have you made to your G-code?
