Practical D1.1:2024 training recommendations
Looking for a short course that goes beyond slides and drills into the real shifts in AWS D1.1:2024 — especially Clause 6 acceptance tied to actual discontinuities. I want a provider that puts gauges in your hand and links WPS/PQR essentials to inspections on A572 Gr 50, 3G/4G plate, and typical shop joints, not just test-prep chatter. I’m sharpening decision-making on borderline indications to protect structural integrity without needless repairs — what programs have moved the needle for you?
decision-making on borderline indications to protect structural integrity without needless repairs — what programs have moved the needle for you? Hobart Institute’s D1.1 Code Clinic did for me: we gauged real 3G/4G A572 plates, then broke/macro-etched the same coupons and re-called them against Clause 6, which stopped me from overcalling shallow undercut and scattered porosity — only caveat is it’s light on UT.
My take: I’d lean toward the simplest next step and see if it changes anything this week — if not, you’ve got a clear case to escalate. What would block you from trying that?
I got the most out of a one-day EWI shop-floor clinic (Welding & Industrial Processes Training | Engineering Classes) where we ran A572 Gr 50 3G/4G coupons, used a Bridge Cam to size undercut and porosity, and defended each call per D1.1:2024 Clause 6 with the WPS/PQR right there. It’s not cheap, but if you bring your own typical joints they’ll tailor it; otherwise ask your local AWS Section to host a hands-on “borderline indications” night.
Lincoln WTTC’s one-day discontinuity lab put gauges on A572 Gr 50 3G — confirm 2024 coverage, @carlton_lee76…
TWI North America’s Practical Welding Inspection hit what you’re after: we gauged real shop joints with fillet/undercut, hi-lo, and pit depth tools, then macroetched a couple breaks to tie WPS/PQR essentials to what showed up. Only caveat — confirm they’re teaching from the 2024 print; their mantra was ‘measure it, then justify it,’ which kept borderline calls from turning into fishing trips. Need a contact there?
WT’s lab gave me ‘gauges in your hand’ — pit-depth/hi-lo — then tied readings to acceptance tables; verify 2024 coverage.
I had good luck with Hobart Institute’s hands-on visual inspection workshop; we logged bridge-cam and pit-gauge readings on shop coupons and had to cite the exact Clause 6 table before calling accept/reject. My tip: ask up front, “are your coupons built to show borderline undercut/porosity and do you tie each measurement to 2024 Clause 6 during debrief?” Small caveat — some sessions still run older decks, so confirm the 2024 update when you register.
