At 6:45 a.m. I had the welder, fitters, and QA staged on Spool 14A with the WPS and preheat at 250 F, then learned the crane was stuck on ROW 3 while the NDE tech texted 5 minutes for 40. What’s the funniest scheduling curveball your cross-functional crew has thrown at a perfectly coordinated plan?
And > What’s the funniest scheduling curveball your cross-functional crew has thrown at a perfectly coordinated I keep a “hot spare” joint staged within 30 ft and a 10-minute rule: if the crane or NDE slips past 10, we swing the induction blanket to the spare, QA does dim checks on the original, and the fitters tack the next piece; saves heat and keeps arc time up — do you stage a backup like that?
I preheat a dummy coupon to 250°F for QA while crane “5 minutes” drags; curious if @anthony_k92’s tried that?
But i’ve had days where the crane’s just decided to take a coffee break, and everyone’s left waiting — like on that 6:45 start time you mentioned. One trick I do is keep a few sections prepped and ready to go while waiting, just in case. It keeps the crew moving even when the plans go sideways — ever tried that?
