Stacking certs and shaping my resume
Just wrapped welding school in May and passed 3G/4G FCAW plate to AWS D1.1 on Tuesday; I booked them the same day to save the retest fee and keep the vertical-up rhythm fresh, and now I’m debating whether to lead my resume with certs + hours (320 lab hrs, booth 14) or projects first — what’s landed you interviews fastest? Targeting a structural fab shop within 60 days, and I want to highlight WPS familiarity and weld symbols without fluff — how are you phrasing those so they pop with hiring managers?
Lead with the certs — ‘3G/4G FCAW to AWS D1.1’ in the top third, then a single line with ‘320 lab hrs (booth 14), vertical‑up focus,’ and link a tiny portfolio; , HR skims and this gets me calls faster than projects. For structural fab, add thickness range and processes you can run day one, plus “available in 60 days” under your name; if you’ve got one standout build, swap it up top with a photo. Got a couple plate pics or a 15‑sec bead video you can link?
Include “booth 14” and 3G/4G AWS D1.1 in subject; link a 30-sec vertical-up clip. Got bend pics?
One tweak that got me quick callbacks was adding a single line under my name with city, cell, and ‘available within 60 days’ — the schedulers sorted by start window and I popped to the top, then I kept certs right below it. Since you already saved the retest fee by doubling up, that hustle reads well; would you be comfortable putting an exact date like ‘start by Aug 15’ in that header?
Open with a hustle line: ‘Passed 3G/4G FCAW back-to-back Tuesday — “saved the retest fee,” kept vertical‑up hot,’ then put fit‑up and print reading on the same line before projects. @jsmith’s subject trick is solid, but also mirror the posting’s terms (beam splices, A36, 3/8 plate) so the ATS flags you. Got a clean pic of a tight root or a hi‑lo gauge check you can drop in?
Lead with certs and a blunt “test‑ready now” line, then two projects that show fit‑up/print reading; work in the 320 hrs and booth 14 so it reads like time on the torch, not just class. That “saved the retest fee” bit is gold — use it as a grit line and add “will take shop test anytime” in the header. Want a one‑sentence opener you can paste in?
