I start each shift by staging leads, taping trip hazards, checking extinguisher dates, and pulling 7018 from the hot box (250°F) with 6010 ready so I can strike the first arc in under 10 minutes without a safety shortcut. Last Thursday on an 8" sch 40 spool piece, that prep cut about 18 minutes off the joint and kept the fire watch from chasing cords — how are you setting up to keep pace and stay within the hot-work permit?
I tack a 1x1 scrap as a “strike pad” next to the piece during staging, clamp the ground to it, and do a two‑second test to dial amperage so the first real bead is clean. If QC won’t allow a tab, I keep a small coupon in my pocket and test off the skid, but the tab saves me more time and keeps arc starts off the work.
Same idea here: I keep a milk-crate “lead tree” with a 50’ cord reel and a snap-hook strain relief — drop, plug, and the fire watch stops chasing cables. With 7018 at “250°F” I don’t crack the can until I’m about 5 minutes from arc, and I use machine presets for 6010/7018 so an 8" sch 40 root starts clean. Only caveat: slick decks get a rubber mat instead of tape so it doesn’t peel mid-shift.
I paint‑pen my machine for 6010 root and 7018 fill (amps/hot‑start/arc‑force) so I just twist to the colors and strike; I also clip a 250°F temp stick to the hot box and swipe the lid before pulling rods so I know they’re right — quick reference: https://www.lincolnelectric.com/en-us/support/welding-how-to/Pages/storing-welding-electrodes-detail.aspx. Only caveat: the marks wear off in grind dust, so a clear coat or a strip of tape over them keeps it legible. You tracking your go‑to settings or the machine?
I park two grinders — flap disc and wire wheel — taped red/blue so I don’t swap wheels mid‑joint; @natalie_b19 that keeps me “under 10 minutes” and saves the fire watch chasing cords. Only caveat: on tight scaffold I go battery‑only to cut trip hazards.
I keep a copper magnetic ground shoe and pre-clean a 2x2 pad on the jig; roll up, drop the shoe, and I’m striking that “first arc in under 10 minutes” on an 8" sch 40 without hunting a return. Only caveat: if the pipe’s scaled or hot, I hit a dime‑size bright spot and clamp direct instead; @natalie_b19 it’s been the quickest setup change for me.
