The 30‑minute kickoff that pays off
On a Brooklyn café build in June, I added a 30‑minute kickoff with a shared spec doc and looped in my powder‑coat partner on day one; revisions dropped from five rounds to two on a TIG‑welded 3 mm aluminum frame. Are others seeing smoother approvals and better referrals when you introduce collaborators early and do lightweight check-ins (I book 15‑minute Tuesdays), or do you manage touchpoints another way?
On a retail fixture, a 30‑min kickoff with the coater and welder cut us from 4 revisions to 1 and landed a GC referral; the trick was a single “tolerance + finish stack” line at the top of the spec so the “15-minute Tuesdays” stay truly light. I also swap one check-in for a 3‑minute Loom so vendors can replay — worth trying?
Quick example: 30‑minute kickoff with a “shared spec doc” plus jig photos cut rework 40%; only works when procurement joins.
I added a 30‑minute kickoff plus a 15‑minute Tuesday ping with a one‑pager and a 60‑sec phone video of the weld prep; it killed the “wrong gloss/texture” surprises () on a TIG’d 3 mm aluminum host stand and got us down to two approvals. I also drop a RAL link in the doc and get a quick thumbs‑up video from the coater before the batch: https://www.ralcolorchart.com — tiny step, saved a repaint. Caveat: it drags if more than three people join, so I cap invites and loop the PM async; anyone else do that?
I ask the coater to post a 10‑second daylight swatch video labeled RAL/texture/gloss + batch in the spec before we tack the first joint; it killed gloss surprises and gave the GC a fast yes/no, but it fizzles if purchasing doesn’t include current lead times. You seeing the same, @OP?
