When it comes to joint integrity, the quality of your filler rods can make all the difference. I recently switched to using ER70S-6 for my pipe welding projects, and I’ve noticed a significant improvement in penetration and bead appearance. Has anyone else experienced changes in their work by opting for higher grade materials?
Totally agree on the ER70S-6! It not only improves the bead but also reduces cleanup time… Ever tried using it with a different technique?
I’ve noticed that switching to ER70S-6 not only helps with the bead, but it feels a bit like upgrading from a rusty old toolbox to a brand new one — everything just works better. Have you tried adjusting your heat settings to optimize the rod even more, @william31?
I totally get your point about joint integrity. I usually pair my ER70S-6 filler with a tight arc to enhance penetration and minimize spatter. Have you tried that method with your pipe welding projects?
