Worth upgrading my MIG gun yet
I’m running.035 on a Millermatic 211 in the college shop, and the stock M-100 gets hot on longer passes, so I’m eyeing a Bernard BTB 200 vs a Tweco Fusion this week — what would you pick for an apprentice who’s leveling up and trying to meet more folks in the trade? Happy to buy coffee if anyone local wants to let me try their setup and talk consumables.
I’d go Bernard BTB 200 — runs cooler on longer beads and the Centerfire tips last; if “M-100 gets hot” is the issue, grab the 45° neck and an extra 0.035 liner. Tweco Fusion isn’t bad, but I spent more on consumables over time. Where are you located in case someone nearby can let you try their rig?
On “.035 on a 211,” the tweak that cooled things off for me was a Bernard BTB 200 with a 60° neck and a tapered Centerfire nozzle/tip, and it only behaved after I trimmed the liner with the wire still in to keep the cut square. Fusion feels lighter, but on “longer passes” I kept bumping the slip‑on nozzle loose, so that’s my caveat. Where are you — if you’re nearby, you can run mine over coffee.
@edavis is on the right track; I’d lean 200-amp Bernard with Centerfire, but use a heavy-duty, larger-bore nozzle and keep about 5/8 in stickout to keep the handle cooler since tapered nozzles tend to feel hotter. The tie-breaker is parts availability; buy what your LWS stocks because you’ll burn tips fast while you’re ramping up. What does your supplier keep on the shelf?
I’d lean Fusion for the lighter cable; mine stopped cooking my hand after I put on the heavy‑duty Velocity diffuser/nozzle and kept about 3/4 in stickout… > you’ll burn tips fast while you’re ramping up. What does your supplier keep on the shelf? If they stock Velocity, go Fusion; if it’s Centerfire, go Bernard — being able to grab tips locally matters more than the logo when you’re starting out; want to try mine if you’re nearby?
On the 211 doing longer beads, I’d go Bernard but spec a 10 ft whip and a 45° neck so the handle stops cooking your hand — , that “M‑100 gets hot” thing drove me nuts. Centerfire consumables are everywhere, so it’s easier to bum a tip and meet folks, though I get @bryant87 liking the Fusion’s flexy lead. If you’re local, DM and you can run mine over coffee.
If you go Bernard BTB 200, spec the 300‑amp neck with Centerfire HD front end — the extra mass soaks heat like a bigger radiator and helps keep that “M‑100 gets hot” issue at bay. Also make sure the steel liner is freshly cut with a guide and seated right; added drag makes the neck run hotter fast. Where are you based — if you’re near Tacoma you can try mine, and here’s the neck/options page: https://www.bernardwelds.com/product/btb-mig-gun/.
